Results 1 to 3 of 3
Thread: V1 and V2 same USB drivers?
    Oct 2003
    Default V1 and V2 same USB drivers?
    I am using V1 and V2 off and on on the same late model XP laptop. I now lose connection during scan and can restore connection only by unplugging and repugging, but even this is a short lived fix. Should I be using different drivers for V1 and V2?
    PowrMax Performance
    100 mm PowrMAF
    Oct 2004
    V1 and V2 should use the same driver package no problems.
    Andrew
    EFILive Crew
    Oct 2003
    Ok, swell. Thanks
    V1 seems to run with the 1.06s or V2s but it sure likes USB2 better than USB1, or so it seems.
    It will drop scan connection in less than 200 frames most times if not using USB2 PCMCIA card while V2 does not seem to care?
    PowrMax Performance
    100 mm PowrMAF
  1. USB drivers Pop-up
    By white01ss in forum FlashScan V2
    Last Post: June 5th, 2008, 04:40 AM
  2. v3 usb drivers
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: February 15th, 2007, 06:20 PM
  3. USB drivers
    By killerbee in forum General (Petrol, Gas, Ethanol)
    Last Post: August 30th, 2006, 12:28 AM
