Results 1 to 10 of 16
Thread: Accel enrichment
    Aug 2005
    Default Accel enrichment
    If I let off the throttle alittle and then press the throttle pedal back down some I get a lean spike briefly running in closed loop. I have looked in EFILive and haven't found anything for this. My buddy has HPT and he found this description and I think this describes it good.
    Acceleration enrichment is a simple throttle transient fuel compensation calculation. Using the change in TPS (TPS delta) as the primary factor, the pcm calculates an enrichment fraction. The enrichment fraction is then added to the current commanded fuel.
    Is there anything like this in EFILive?
    John
    2000 SS Camaro
    LSX 427 with GT55-94mm
    9.77 @ 157 4030 lbs race weight
    Aug 2005
    BTW I am running Custom OS 5.
    John
    2000 SS Camaro
    Aug 2005
    I've put in a request to have these added. Ross has said that it will have to be after the next release.
    I have a lot showing a lean spike where commanded is 11.7 and actual is 15.6! Boost comes in at 3psi 1/10 of a second later, 6psi at 3/10 later.
    Aug 2005
    So you are saying right now nothing can be done about it? If that is true then screw closed loop, I will go back to open loop.
    John
    2000 SS Camaro
    OL is fine.
    I'll move this thread to the COS thread.
    Aug 2005
    OL is fine.
    I agree OL is fine. It would be nice to be able to run in CLSD and not get the lean spikes when you increase the throttle.
    John
    2000 SS Camaro
    Mar 2007
    Quote Originally Posted by Camaro SS
    The Acceleration enrichment section is blank in the LS1,LS2 & L76 operating systems in HPT , it's in the V6 calibrations .
    Jun 2005
    I think this is primarily because the exhaust is down stream from the whole comubstion process. If the PCM switches immediately from 14.6 to 12.5, the injectors will respond virtually instantly. But, you still have to burn the mixture and send it down the exhaust tubes. If the lean spike is for more than .3~.5 seconds, then I would worry. Otherwise, expect a delay in what your WB reads vs what the PCM commands during transitions.
    Aug 2005
    Quote Originally Posted by SSpdDmon
    It's not that, it's a very real lean condition. Upon throttle application in speed density, the WB will read lean, not just show positive BENs. In my case, the WB will go from 14.7 up to 16.5 for a moment before tapering down to commanded. Detonation is right around the corner when you're boosted. :(
    Aug 2005
    I agree with you on your statement but if I get a lean spike to say 16.0 you couldn't even tell it if I didn't have a wideband but sometimes it will go to almost 17.0 and the car stumbes for a spilt second. I am sure if I would run a maf I wouldn't have this issue but I am planning on putting a F1A on soon so I will be running SD and I would like to be able to run closed loop.
    John
    2000 SS Camaro
  1. Will changing the VE map alter accel pump/transient fueling?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: June 18th, 2009, 08:10 PM
  2. B5208 Rev limiter accel modifier
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: September 22nd, 2008, 07:47 AM
  3. Need help tuning gmpp intake w/ accel 1150cfm tb
    By wadesns in forum Gen III V8 Specific
    Last Post: July 13th, 2007, 04:25 AM
  4. RPM remains high after accel
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 26th, 2006, 02:55 AM
  5. MAX Enrichment?
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2005, 12:03 PM
