thanks!! So far I am loving efilive and my car doesnt even run!! I can turn the key on and monitor IAT or map
Sent the file. I set up the wot commanded table that I'm playing with...works well so far. Plus the cold start vs coolant temp,etc,etc.
thanks Tom!!! I was just copying some of your stuff this morning. my 3 bar scaler ended up around 282 and of course was easy to do in realtime
What injectors do you have? I assume 160# by the 900 number you have in IFR
IFR is 8.2 to 9.0 .......900????Originally Posted by Cablebandit
It's a slope set-up for the 60's I'm running since the fuel is boost referenced.
i swear it said 900 under IFR which was the max....maybe i was high on gas fumes sitting in my non running car
