Results 1 to 9 of 9
Thread: no more Vortec PCM!
    Jan 2007
    Default no more Vortec PCM!
    Finally got around to converting the vortec PCM to the 0411 99+ PCM.
    Much better!
    Took around 3 hrs to complete.
    Cool, if only the 1998+ F-body guys could do it so easily.
    Jan 2007
    Hi Ross,
    Exactly what does F-body mean? I've seen this talked about alot.
    There are alot of guys converting from 97 & 98 to the 99+ 0411's.
    Feb 2006
    The F-body refers to GM's way of labeling chassis. The F-car is a Camaro or a Firebird.
    Feb 2006
    Hquick do you have your fuel gauge working too?
    AL
    Jan 2007
    Yes Al.
    Works fine!
    All guages are working as per normal.
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Yo Howard
    I like the whipple gauge the best....
    pegs your 1 bar at 1650 rpm..
    Jul 2005
    Any idea if this swap would work on an OBD-II LT1? I would so like to tune my Cutlass......
    '03 GMC 1500HD
    '79 Pontiac LeMans-LQ4/4L80E
    '05 CTS-V
    Jan 2007
    Don't know Dave...anything's possible.
    I have seen mention of the 0411 swap in other vehicles on different forums.
    I think I just did a search for "0411 PCM".
    May be worth a try.
    Maybe you'll be the first!
    Howard
  1. vortec 4.3
    By 770johnnyw in forum Vortec V6/V8 Specific
    Last Post: April 11th, 2010, 02:55 AM
  2. vortec v6 to vortec v8 swap
    By grezzmky in forum Vortec V6/V8 Specific
    Last Post: September 21st, 2009, 05:49 AM
  3. 08 Vortec Max cng
    By 05lly in forum E37, E38 & E67 PFI ECM's
    Last Post: June 23rd, 2008, 09:29 AM
  4. 96/97 vortec
    By 69camaro5speed in forum General
    Last Post: January 1st, 2008, 05:01 PM
  5. 96-98 Vortec 5.7
    By Buzzard in forum Vortec V6/V8 Specific
    Last Post: May 24th, 2007, 10:31 AM
