Results 1 to 6 of 6
Thread: 2k2 C.E.T/A LS1 to LS6 conversion
    Mar 2007
    Default 2k2 C.E.T/A LS1 to LS6 conversion
    Hi
    I just bought 243 heads and 5308 cam which are stock on the LS6 engine
    I also bought a smooth bellow and air lid. The engine already has an LS6 intake.
    Do I need to flash the ECM for this configuration? If so is there anyone that has a setup like this and has anyone run a tune on one. I am new to this, so I have a lot to learn.
    2k2 Trans am, ls1, 4l60e, slp lid, smooth bellow, k/n filter, ls6 intake, ls6 short block,
    Thanx
    Jan 2004
    Welcome to the forum. I would start with your stock OS and go from there. Check the air fuel if you have a wideband and dial in the car to how it wants to be. Do a search for AutoVE and you can use that information to help with the tune.
    Mar 2007
    Hi
    Thanx for the info
    I will do as you requested and go from there.
    Jan 2005
    Think of it this way-- you've done the equivalent of installing an LS6. If you're concerned about finding a good starting point, you can download a stock Z06 bin file and copy the values from the VE table. If you download a version based on the same operating system as is in your PCM, you can do a direct compare of values. If you start looking at other tables, keep in mind that the Z06 is drive by wire, so some of the IAC and throttle-related data may not make sense.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Mar 2007
    I looked at the downloads and got a z06 tune. I have not compared the ls6 to the ls1 yet. I am still fumbling around with the program first. I want to get a better understanding of it before I start tuning my bird. Thanks for all the help.
    Zentor
    Junior Member JuhaniLS1's Avatar
    Nov 2006
    Have done similar swap, 243 ported heads big valves on LS1 with shorty headers and comp 216/220 cam LS6 intake. So far have only copied LS6 Spark tables and put EGR off, but -02 dont have that. It works and drives otherwise on -99 LS1 tune. Have looked LS6 VE table and it differs from mine, going to test what it does next.
    Camaro SS Hyper Blue EU -19
  1. Please help with LS2 conversion
    By jasonsfbodies in forum Gen IV V8 Specific
    Last Post: August 3rd, 2010, 12:42 AM
  2. vz ls1 to l98 conversion
    By shane in forum Gen III V8 Specific
    Last Post: November 30th, 2008, 10:41 PM
  3. E-85 Conversion
    By vatman02 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2008, 01:53 AM
  4. MIL for a LS1 conversion
    By Biggsy in forum Gen III V8 Specific
    Last Post: April 7th, 2007, 04:44 PM
  5. 3rd Gen conversion
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2006, 08:48 AM
