Results 1 to 6 of 6
Thread: What does this mean?
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Default What does this mean?
    I got it while downloading the PCM file from my car. I also get it when I try to initially open the file I got from my PCM in the tuniing software on my desktop,
    Elmer
    Jan 2004
    Yup, that is normal with this release. You need to send your tune file to Ross and he can then build the cal files for it. Once the cal files are done, there will be another update which will allow you to physically look at the tune.
    Aug 2004
    send me the tune. ill look and see what it is going on. jessebubb@yahoo.com
    Apr 2004
    Quote Originally Posted by wait4me
    Coming at you.
    I've sent 1 copy also to support@efilive.com
    Elmer
    Apr 2004
    BTW, did you need any explanation of the options on the car other than 2007 Corvette LS2 M6?
    No, none needed, I just look the VIN up here - http://www.vehicleidentificationnumber.com/carfax.html
    That usually tells me enough.
