Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Which wideband O2?
    Jan 2007
    Default Which wideband O2?
    I've been searching the forums but can't find anything specific.
    I need to buy a wideband O2 sensor/setup but am unsure of which brand/type to get.
    Can anyone recommend one?
    Howard
    Jun 2005
    Innovate Motorsports LM1
    Lifetime Member Rhino79's Avatar
    Jul 2006
    I love my PLX!
    Oct 2006
    I bought the LM-1 as I wanted a unit to swap between different cars. If you are only doing the single vehicle you could go for the LC-1. Both are available from members on this forum.
    Jan 2007
    Default Thanks guys
    That's some of the info I was after.
    Which are applicable to be used on multiple vehicles.
    What are the pro's and con's of each type/brand?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jan 2004
    The LM-1 is my choice for wideband to use when switching between vehicles. Pro's - Easy to move, Easy to setup (3 wires), Inexpensive sensors
    Con's - Display box is kind of large, if the vehicles cigarette lighters don't work your screwed. LOL
    Honestly, the only disadvantage I can see with a LM-1 is the display box. It isn't that large, but not easily hidden.
    Jan 2007
    I was thinking PLX but not sure.
    I noticed it's supported by EFILive as is the Innovative.
    I know nothing about wideband O2 sensors except that I NEED one.
    Thanks for the help guys.
    Howard
    DUCT TAPE.
    Oct 2003
    PLX is truly plug and play-no calibration ever!
    PowrMax Performance
    100 mm PowrMAF
    Mar 2005
    I have a PLX-300 w/digital display that I have used in my truck almost every day for over a year with no problems and it always has worked with no calibration hassles. It still has the orginal O2 sensor. It is a small unit and I plug it in to cig lighter outlet so I can also use it on other vehicles for VE tuning. I can recommend it based on my experience with it.
    2014 Silverado 4X4 6.2L
    2010 Camaro 2SS-RS L99
    2007 Sierra Denali 6.2L
    2005 1500HD 4X4 Quadrasteer 6.0L, COS3 SD
    Lifetime Member N0DIH's Avatar
    Jan 2006
    Don't get slightly bit like I did. I jumped on a sensor a friend of mine showed me on eBay and it is one for a AEM controller (not cheap!). $65 to the door at least. But the connector is wrong for IM LC1/LM1.
    The AEM controller is pretty nice, but I haven't really compared it to the LM1 to see how they stack up.
    Anyone know?
  1. wideband?
    By drdarthinvader in forum Purchase and Shipping
    Last Post: September 20th, 2008, 03:26 AM
  2. rr & wideband...
    By rubbersidedown in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 5th, 2007, 08:39 PM
  3. fjo wideband
    By articSS in forum External A/D inputs
    Last Post: May 27th, 2007, 09:02 AM
  4. PLX Wideband SM-AFR
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2006, 02:46 AM
  5. wideband way off with V2
    Last Post: December 10th, 2006, 09:13 AM
