Results 1 to 5 of 5
Thread: Injection Timing During Cranking
    Mar 2007
    Default Injection Timing During Cranking
    I am trying to adjust the injection timing during cranking for my LBZ duramax. I have used several different values for the 300 & 600 RPM and have yet to note/observe a change from the Virtual Dashboard.
    What do I need to do in order to advance injection timing? My understanding is that all you need to do is modify the map, save the changes to a .Tun file, then reflash the ECM. Since there are 5 versions of the main base injection timing, I made each map (A-E) to be the same.
    Is there a separate map for cranking? Why isn't it responding to my changes?
    In the LB7 / LLY ECM's there was a cranking table, the Bosch ECM probably has one too but as yet we've not found it. I've bumped it up the list of things to do for you
    Mar 2007
    Haha. Ross you are too kind. You guys really are helping me out a lot and I truly appreciate the effort. Hopefully some of my questions have helped spark ideas for your LBZ software development.
    Oct 2005
    Quote Originally Posted by thetallengineer
    Why are you wanting to change the timing during cranking?
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
    Mar 2007
    My engine is connected to an engine dynamometer and therefore has extra inertia to turn during cranking. The stock starter has difficulty spinning the engine fast enough for it to start running. I was going to play with the timing to make a more aggressive starting strategy and compensate for the additional mass.
  1. Interesting info on B3702 Injection timing
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: April 6th, 2019, 10:44 AM
  2. Injection Timing / Pilot
    By Lennart in forum General (Diesel)
    Last Post: January 20th, 2012, 03:05 AM
  3. injection timing after pilot c,d?
    By SGFastMax in forum Duramax LB7
    Last Post: February 3rd, 2010, 03:35 PM
  4. Cranking Injection Qty Map
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 3rd, 2007, 08:54 AM
  5. injection timing
    By 02gmcwaldoch in forum General (Diesel)
    Last Post: March 18th, 2006, 07:43 AM
