Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: issue with 7.4
    Nov 2006
    Default issue with 7.4
    i have just installed the new version 7.4 and have noticed that the tables in the tune tool that used inHg measurements now use Psi instead but the scan tool only shows the pids in kPa and inHg.
    has this been over looked?
    will this be a problem?
    Sep 2003
    Change you display units Edit ----> Configure Display Units
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Instructions on how to change the display units.
    Nov 2006
    thanks for your reply , but i don`t think you understand me.
    7.3`s options for imperial where inHg and metric where kPa.
    7.4`s for imperial are Psi and kPa for metric.
    metric didn`t change but imperial did.
    Jan 2004
    Quote Originally Posted by mr.prick
    Your right, we didn't. Sorry. :( I will let Paul know about it. I wonder if it is something they changed to. I just checked and all of my tables are in PSI as well for imperial.
    Nov 2006
    i am an imperialist!
    Can you please post example calibration identifiers that have changed. And I'll investigate what happened and how to fix it.
    Nov 2006
    all my maps where off because they where inHg and now the tables are Psi.
    i cant be the only one using imperial settings.
    the pids haven`t changed but the tables in the tune tool have.
    Attached Images Attached Images
    I don't know about you guys but I cannot make out anything on this picture. Maybe if you save it as a jpg it will be a larger resolution.
    Al
  1. 427 L92 a4 GTO issue
    By 10secvette in forum Gen IV V8 Specific
    Last Post: January 26th, 2014, 11:32 AM
  2. New Guy with TCC Issue
    By OldGreg in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 30th, 2009, 04:21 PM
  3. LC-1 Issue
    By jermstyle in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2009, 10:36 AM
  4. BBL and E38 COS Issue
    By swingtan in forum FlashScan V2 BB Logging
    Last Post: October 29th, 2008, 11:00 AM
