Results 1 to 10 of 13
Thread: Problem installing 7.4
    Nov 2005
    Default Problem installing 7.4
    Since there isn't a software area (no one has problems maybe?) I'll post this here, if there's a better spot please move it.
    Here's the deal. I can't get 7.33 or 7.41 to install. 7.32 installs fine. Whenever I try with the newer versions I get "this installation package could not be opened. Verify that the package exists and that you can acess it, or contact the app vendpor to verify this is a valid windows installer package."
    I installed XP sp2, the newest windows installer I can find (3.1) and I can't think of anything else that I can do on my end to make it work.
    Nov 2005
    I also downloaded both files several times to be sure it wasn't a problem with the files.
    Nov 2005
    Odd. I finally moved it and renamed the folder and then it installed...
    Is it possible the file you downloaded was originally saved on a shared or network folder/drive? Sometimes windows grants different permissions to file/folder accesses when they are shared/networked. That can cause porblems like you decribed.
    Aug 2004
    When you start the software, did you extract the contents first?
    Oct 2006
    I can get the split zip file to download but none of the others. I keep getting a page moved or unavailable message. Is there a problem with the links for the split files ?
    Quote Originally Posted by 5.7ute
    Sorry, its a problem with the file extensions which are *.zip_001, *.zip_002 etc. The web server has not been configured to allow downloads of files with those extensions. I'll get it fixed asap.
    Oct 2004
    So this is the problem you PM'd me about obviously... I hadn't imagined that you'd need to download the split files. Most place sin Oz have good broadband
    Andrew
    EFILive Crew
    Oct 2006
    We are stuck in a shadow of the wireless connection on optic fibre cables. So much for Telstra moving forward in remote areas.
    Oct 2006
    Cheers mate. Damn dial up
  1. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  2. Help w/ installing driver for Lc-1
    By 99TransAmls16spd in forum General
    Last Post: June 24th, 2008, 06:44 AM
  3. Installing wbo2
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2008, 11:20 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
