In the mean time... I can right click on the links in the download thread and choose 'Save Link As'. That should work for you also I'm guessing.
Andrew
EFILive Crew
I tried that as well & still get the site not found message. It must be some internet exploder thing if you can get it to work O.K. Then again if I click on the full version it directs me no problem.Originally Posted by Tordne
Blacky, Jessy- I had downloaded it normally. Several times actually. When I extracted it I had just let it name it the same as the zip file (using winrar) and into the same folder the zip was in, since it defaulted there. I am thinking that was the problem, perhaps windows confused the zip and the folder... I moved it to my temp folder instead and renamed it just EFI and then it installed.
