First off I'm a newbie so be easy..
I'm a little lost on the IFR table.. here are the rate's that are in now (someone else figured them) and the rates for what redhardsupra chart says..question is how much of a difference would that make.. (motron 60's fuel pressure at 62psi)
Whats in there now
7.484375
7.531250
7.570313
7.625000
7.671875
7.710938
7.765625
7.804688
7.843750
7.898438
7.937500
7.984375
8.023438
8.070313
8.109375
8.156250
8.203125
What redhardsupra .xls sheet calls for.
8.952454
9.005512
9.058260
9.110702
9.162844
9.214692
9.266249
9.317520
9.368512
9.419227
9.469670
9.519847
9.569760
9.619414
9.668813
9.717961
9.766862
The reason I'm asking is on the stock OS the car will pull through boost just fine but is a little lean..once I loaded the COS the car goes pig rich around 115 kPa and starts bucking.
I'll attach the tune i'm on now 04 GTO M6.. also I do have ethanol coming in at 5psi, 255 pump and KB BAP
thanks in advance
