Well guys i finally found the time to make the switch to cos 5. I went through all the tutorials, and merged my 2000 os with the corresponding 2002 os. Well i made all the switches and everything and got it all into the car and it starts and runs... very happy with that. BUT after all the time i spent merging the files the dang thing wont idle worth a crap now.
Before i did the merge i got the car to where it would start up and idle perfect. It would go strait to the correct rpm and never had a hickup, now the thing searches for idle if it starts at all without giving it some gas to keep her alive. Once again i went through the cos tutorial and made all the changes it requires. The files i were using were in SD mode, running mafless, it was setup to where i was autoVE'ing it everytime i drove it. I copied everything almost exactly where it could be , so i thought
My thought maybe that since the 2002 tun has so many different maps compared to a 2000 , and some didnt correspond, that may be part of the problem....ill post some files....
one is the COS5 file that im using, that starts the best.
the other will be the latest original OS that was idling PERFECT
ill also throw in a screen shot of start up (bad idle, had to give it gas to keep from dying)
