B3647 is setup exactly how the COS tutorial shows it to be. It is complete different map now that i have changed over to COS5. the stock OS map is ECTvsMAP where as COS5 changes it to RPMvsMAP. however i did add some more fuel from 75kpa up to make it follow the old map closer. What EQ should i be running from 20-70kpa , i just had it at 1 like it shows in the COS tutorial and in the autove tutorial.
i went through and made the changes you pointed. Some of those im not quite sure how they got changed. I went back and looked at one of my very first tunes i did and they were where they should have been... interesting.
A0008 i added some fuel down in the colder area, we will see how it helps.
thanks for all your help. I knew if i posted it up you guys would help figure it out.
Thanks again,
ill give this new tune a try next time i play with the car, will probably be late next week b/c its supposed to rain here from now til then.
