Results 1 to 4 of 4
Thread: Seeing identical values for MAP and MAF readings
    Nov 2003
    Default Seeing identical values for MAP and MAF readings
    Hi,
    not sure if this was covered in the past:
    I noticed that while logging MAP and MAF (lb/min) both
    have identical values under all conditions, for example
    at WOT both have 29.8. I currently have V7.2.2 build 236
    and obdiiV7.2.2 build 374. It looks like th MAF readings
    is wrong, the MAP readings are correct (what you would expect under
    various conditions).
    Gert
    Can you send your log file to me at paul@efilive.com and I can hopefully figure out what is happening. (I may not get a reply to you until after Nov 7, I fly out for SEMA tomorrow).
    I loaded the log file here and it displays ok.
    Have you put the MAP PID on the charts twice and just renamed one of them to MAF?
    Check the values in the [Data (F9)] tab page.
    Oct 2003
    yes, some of the beta versions had the parameter selection missing for the MAF entry on the charts. I guess it just displayed the value from the previous .pid.
    You need to go in and properly specify the parameters to be displayed for the charts.
    2003 Silverado SS
    N/A: 14.257 @ 94.63 mph
    N2O: 13.200 @ 102.3 mph
  1. What are your MAP readings?
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: April 19th, 2010, 08:48 PM
  2. Torque / HP Readings
    By Duramax 6.6L in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2009, 03:54 AM
  3. MAP Readings in a 5.3 Vortec
    By RacerChris in forum Gen III V8 Specific
    Last Post: February 26th, 2009, 02:18 AM
  4. AFR readings low through EFI
    By Chalky in forum General
    Last Post: May 18th, 2006, 03:24 PM
  5. DESIAC_B values and MAF values keep trimming down. Help!
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2005, 01:54 PM
