Results 1 to 3 of 3
Thread: Prior to installing V7.2.2 - registry modification?
    Nov 2003
    Default Prior to installing V7.2.2 - registry modification?
    I checked my registry and found four files
    in the HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Shared DLLS,
    the three listed (to be deleted) on the website (Scan.exe,Tune.exe and obdiiV7.dll
    and also C:\Program Files/EFILive\V7\FTD2XX.DLL
    Should this file remain in the registry?
    Gert
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    I left that file in mine and all seems to be fine on the installation.
    Default Re: Prior to installing V7.2.2 - registry modification?
    Quote Originally Posted by 2000ssnb
    Gert
    You can/should remove the "shared" registry entries for all EFILive files that are marked as shared - none should be.
    That one won't matter because it did not change between V7.1.8 and V7.2.2 - it is the USB driver code.
  1. Installing the V8 Software
    Last Post: April 18th, 2022, 11:39 AM
  2. Installing the V7.5 Software
    Last Post: February 9th, 2021, 11:28 AM
  3. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  4. Requested DTCs for modification (LBZ)
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2007, 04:57 PM
  5. Modification history
    By GMPX in forum Tips and tricks
    Last Post: August 7th, 2006, 03:46 PM
