Results 1 to 5 of 5
Thread: 0411PCM Suburban 4x4???
    Jan 2007
    Default 0411PCM Suburban 4x4???
    Hi All,
    Don't know if I've got this right.
    I recently swapped my Vortec PCM for an 0411 PCM.
    My truck is a 98 K1500 (5.7L 4x4 with the 4L60E trany).
    As yet, no one that I know of has done the 0411 swap into a 4x4.
    How do I go about including whatever 4x4 tables are necessary in my custom OS (02020003).
    Hope that all makes sense???
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Dec 2005
    Hey Howard,
    I don't have 4wd myself, but I don't think that the .tun files for automatic transmissions have separate 2wd/4wd calibrations; I think they're both included in the same calibration. If you open your .tun file and search for "4wd" in the search field at the top left of the screen, you should be able to find the parameters/tables corresponding to 4wd operation I think. Not 100% sure, but that's what I saw when I just looked right now. Let me know what you think
    Max
    98 Chevy truck RCSBFS 2wd/5.7L/4L60E:drive:/Paxton Novi 2000 S/C @ 7psi / Megasquirt
    72 Chevelle LQ9/4L80E/GT42 conversion in the works
    http://www.ls1tech.com/forums/showthread.php?t=449129
    Jan 2007
    Yeah, I was thinking the same thing Max. Actually, that's how I found the tables.
    I think it will be fine.
    I've been away for the weekend...long drive, took a couple of 1.5hr logs.
    I was tempted to push the 4x4 botton whilst I was away but decided I'll push it in the morning and see what happens!
    "Hmmmm....what does this button do?"
    Howard
    DUCT TAPE.
    Feb 2004
    Quote Originally Posted by hquick
    So what did it do?
    01 C5 'vert A4
    EFILive, PLX, & TNT are all we got at the moment.
    Jan 2007
    Sorry...forgot about this post.
    Everything worked as per normal.
    Howard
    DUCT TAPE.
  1. 5.3 Suburban w/22's
    By horsehaulin in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 12:21 PM
  2. 5.3 liter 2002 suburban
    By x MadMAX DIESEL in forum Vortec V6/V8 Specific
    Last Post: December 30th, 2009, 05:27 PM
  3. 0411PCM swap and 4x4
    Last Post: April 9th, 2007, 11:21 PM
  4. 07 suburban
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: August 5th, 2006, 04:03 AM
  5. Tuning '03 suburban with procharger
    By Chunx in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 1st, 2006, 06:26 PM
