I have three logs that show main pulse width in the 300-400us range. I also have a previous log(different truck) that showed the correct pulse width. Any ideas?
04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
Was the one that wasn't reading correctly an 06 LLY?
No, it was an 06 LBZ
There was an error in an earlier release that showed Pilot times instead of main. This was using V7.4?
Could it be related to OS 12604138 (06 LBZ), I have successfully scanned OS 12606128 without issues.
I believe my EFILive is current, Scantool = 7.4.2 build 515, build 644, Tune = 7.4.2 build 622 w/205 calibrations available.
Those pulse times are not a standard GM supported PID, we (EFILive) must define those for each OS, so yes it is possible that it works fine on one O.S but not another.
