Originally Posted by
GMPX
On some computers it is not possible to read the entire flash, both the LBZ ECM and TCM (in a a way) fall in to this catagory. On all the Delphi computers we are able to read the entire flash memory.
This is one of the reasons we don't have full flashing on the LBZ ECM, though we could program the 2Mb of flash and the CPU's internal flash we can't read it all out, the ECM won't let us, we needed to use a debug port on the CPU to get all the data out (you need to rip the ECM apart to get to it).
The Allison LBZ TCM will allow a full read, but, it places some restrictions on the speed it can be done!, we decided not to read the entire TCM because that would take about 45mins! (we timed it), instead we only read the calibrations and some other vehicle specific data from within the flash.
Samdogmx, I believe Andrew at support is working with you on your problems?
