Results 11 to 20 of 33
Thread: Convert 98 to 02
    Yes Garry you can add the information to the Wiki.
    When you write "Red C1-60 BRN, Blue C2-19 PNK, C2-58 PPL and C2-20 ORN remain in the same locations"
    This means you don't have to do anything with these circuits. See the excel file for the "new" circuit location.
    Jun 2006
    OK, understood ... I added the pins to the table I made in the Wiki, so anybody just doing pin by pin should get it right
    Nov 2003
    This is great news! What about the ECT gauge?
    [edit]
    Never mind....It will operate the same as it will still use the same sender and gauge cluster....
    Nov 2003
    Quote Originally Posted by Garry
    I am sorry but I do not understand "Wiki".
    How do I fine the table you are talking about?
    John
    Nov 2003
    Quote Originally Posted by ChipsByAl
    I used the 2002 Camaro/Firebird OS 12212156 (available from http://www.holdencrazy.com) for the base file. I then used the fuel segment from the 2002 Express Van OS 12212156. Since the fuel tank and sender are different, I then copied the fuel system parameters, fuel gauge calibration and Convert sender to volume tables back from the Camaro/Firebird base file. I just looked and Tordne doesn't have the Express Van on his site. I will email him one.
    Al
    The 1998 F-body fuel tank holds 15.5 and the 99+ hold 16.8 gallons. Shouldn’t you use the stock 1998 calibration data in the 2002 flash?
    Jun 2006
    Quote Originally Posted by jnorris
    http://gmtuning.info/wiki/index.php/98PCM
    Nov 2003
    Good point, jnorris. The conversions I did were close enough just like that. You can definitely fine tune the fuel gauge better than my rough in.
    Al
  9. #19
    Oct 2003
    Wow, this is awesome!
    What is meant by "TEST FIRST!" on that one pin though?
  10. #20
    Sorry if I confused anyone. That was a note to me to check that circuit. It does work with the segment swap and update of Camaro/Firebird fuel parameters. I have changed the document for all who want the corrected version.
    Al
  1. can anyone convert ant hpt file into efi?help,help
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: December 19th, 2009, 09:10 AM
  2. help! convert to ETC/drive by wire
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 08:46 PM
  3. Convert ETC to cable TB
    By xtreme in forum Gen III V8 Specific
    Last Post: March 23rd, 2009, 10:52 PM
  4. Anyone willing to convert my PLX to serial???
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: November 16th, 2008, 04:51 PM
  5. LS1 Edit convert... first post with Q's
    By Chicago Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 15th, 2005, 08:11 AM
