Results 1 to 3 of 3
Thread: EFILIVE and egr LBZ
    Junior Member heathgu's Avatar
    Feb 2007
    Default EFILIVE and egr LBZ
    G'day guys.
    I know you can disable the egr with efilive does that mean i can completely remove it from the engine i am having some clearance issues with my bonnet and will have to remake the inlet pipe into the inlet manifold. Need the room that the egr now occupies.
    I do not need it to pass emissions.
    Just asking thanks heaps heath.
    LBZ/ALLISON going into a NISSAN GU PATROL UTE some how???
    Sunshine Coast, Queensland.
    Lifetime Member IdahoRob's Avatar
    Apr 2006
    Yes you can completely remove it. I did on my LLY, same thing for the LBZ.
    You'll have to make a plate to block the up pipe where the exhaust flows into it. You'll also need to extend the coolant hose. That's about it.
    Good luck.
    2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
    2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
    1965 El Camino, duramax 9.6 @ 149MPH
    All EFI tuned by Adrenaline Truck Performance
    New Member rlj4214's Avatar
    Apr 2007
    2007 LBZ. What settings do you use to disable the EGR?
    I poked around a bit on Diesel place but the stuff I found doesn't match up to what I am seeing in the tuning tool.
    thanks,
    rlj
