Results 1 to 8 of 8
Thread: User Notes
    Aug 2006
    Default User Notes
    When I add a note in the USER COMMENTS tab for any given table, that note goes to the same table tab for other tunes in my collection. Any Thoughts ?
    Jan 2007
    Hey...so it's not just me!
    I noticed that whilst playing around with my fuel tank settings. I thought it odd that others had typed exactly the same thing as me in those note tabs.
    Ha Ha, now that's funny...I didn't pick up on that Jeff!
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Aug 2006
    Actually I had the same thought as you Howard. The first 8-10 times I saw this, I thought--Man, that is written just like I would have written it, it even has the same numbers. Duh! Hopefully someone can explain/correct this.
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    If I remember correctly, when you put comments in 'User Notes' it goes in a file in the folder '\My Documents\EFILive\V7\User Configuration\Notes' such as 'B5934.txt' or whatever table you made the comments about.
    When you open any tune file that has the same table number, the comments are displayed. In other words, they are table specific not tune specific.
    Aug 2006
    Ninety8C5, Thank You. That is not exactly the answer I hoped for. I wish the notes were dedicated to their own tune.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Quote Originally Posted by Lextech
    I would like that feature too
    Dave.
    Jan 2007
    Default That's crazy!!!
    I put 'rescaled for 159L' in my notes for my tune and it added it to other tunes that weren't rescaled.
    This could cause some serious confusion.
    Howard
    DUCT TAPE.
    Sep 2003
    I don't think the 'Users Notes' are there for indivual Tune comments but for general comments like 'increase this table to richen A/F ratio...'.
    If you want to make 'tun' specific comments use the 'Comments' tab under the 'Details' window that appears when you open a 'tun' file (Table Bxxxx rescaled for 159L).
  1. Tuning Notes by WeathermanShawn
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: July 12th, 2013, 02:21 AM
  2. New user
    By VACARELLAB in forum Duramax LB7
    Last Post: April 4th, 2009, 03:39 PM
  3. Release notes
    By PSWired in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 02:40 AM
  4. Beta Releases and Log Files Full Of Notes
    By swingtan in forum FlashScan V2 BB Logging
    Last Post: April 28th, 2008, 09:10 PM
  5. New user needs help
    By LowETz in forum General (Petrol, Gas, Ethanol)
    Last Post: May 4th, 2007, 01:39 PM
