Results 1 to 10 of 19
Thread: Spark tuning in real time....
    Default Spark tuning in real time....
    We'll I finally got a chance to play with our RR unit today. What a slick unit!
    I wanted to check out the spark control and noticed that while looking at the spark tables that there wasn't a grey box showing the actual cell. Now that I am typing this I think I just realized that if you use the pids outlined in the AutoVE tutorial, none of them are the pids to log load as is indicated in that spark tables.......
    I guess if I selected a calculated load parameter, non direct MAF, that I should have been able to also play with spark in real time. Did I answer my own question?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jan 2004
    Sounds like you might need some counseling if you keep talking to yourself. :lol:
    Mar 2007
    id like to know this as well.
    Jan 2004
    You will need to setup a BEN factor for the timing or equivelant. Then you will need to take the correct PID and adjust the link.txt file to show the correct PID placement.
    Aug 2005
    Quote Originally Posted by Redline Motorsports
    Howard
    Hi Howard,
    If you're logging GM.DYNCYLAIR and RPM, it should track the cells in realtime.
    If you haven't done it yet, I would highly recommend downloading the latest firmware for the RoadRunner. It resolves a glitch that will occur from time to time when using RTACS that causes the PCM to hiccup. Can be startling at full load!
    Justin
    That was the answer I was looking for. I was so consumed with the VE table and using the AutoVE pids I forgot to enable a calculated load pid.
    Chad, elaborate on the BEN for timing.
    DC, where do I get the latest firmware for RR?
    1-954-703-5560
    Aug 2005
    Latest firmware can be downloaded here: www.moates.net/zips/firmware/
    BEN for timing...Can't be done yet... unless you want to use the spark scaler... but that would be akin to tuning timing based on the knock sensors...
    Once there is some sort of dyno integration with flashscan, then you may be in a better position.
    Thanks for the link. I assume I can still add timing in RT while keeping a load on the car.
    Another RR question I have is; if you are manually changing values in a cell is there a way to arrow up or down to change the values or do you have to type in the exact value and hit enter every time?
    I agree that torque feedback from the dyno would be required to accurately calculate peak cylinder pressure.
    1-954-703-5560
    Junior Member MCG's Avatar
    Jul 2005
    The best way that I've found to tune in a spark table is with a load dyno and a 5 gas analyzer. Between the two, you can dial it in nicely.
    F8 = up 1.0
    F7 = down 1.0
    Ctrl+F8 = up 0.1
    Ctrl+F7 = down 0.1
    Ctrl++ = up by currently selected/displayed precision
    Ctrl+- = down by currently selected/displayed precision
    Those hotkeys work in ALL tables and parameters. It also changes ALL selected cells when multiple cells are selected.
    And if you turn on blending (Ctrl+L for linear and Ctrl+Q for quadratic), then the surrounding cells are blended (pulled up/down) with the changes you make using the hotkeys. Turn off blending with Ctrl+B. Use the toolbar to adjust the size and shape of the blend area.
  1. Real Time tuning w/o Road Runner?
    By Treed ya in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2008, 06:40 PM
  2. HP Tuners Custom OS for Real Time Tuning compared to EFILive RTT?
    By N0DIH in forum Custom Operating Systems
    Last Post: July 14th, 2007, 03:23 PM
  3. RoadRunner Real Time Tuning
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 08:47 AM
  4. Live Real Time Tuning?
    By Nox in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2005, 02:08 PM
  5. Real time tune ?
    By Clubsport R8 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 30th, 2004, 12:13 AM
