Results 1 to 10 of 17
Thread: Torque Management reduction
    Default Torque Management reduction
    How much can we reduce torque management tables before we are on the edge but still free the car up from TM? I have a couple 05' A4 goats to tune and would like to firm up the shifts as well as reduce the TM so we can get less spark reduction down low and in the mid range.
    I found a table B0515 Torque Reduction by spark option. If this table is set to disable, shouldn't it eliminate all spark related reductions regarding TM? I wonder if this would have less of an impact on the trans as opposed to some of the trans TM tables..
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    I have no idea for the LS2 in the goats, but I know for the I6 you can remove as much as you want b/c the 4L60E should hold all 275/275 the engine can put out. I have almost all of mine gone, I think I have ~15% in each the trans and the engine left as that is what makes my shifts nice and firm. I might play with pulling even more out when summer rolls around and I have a little more free time.
    I wouldnt hesitate to pull ~50-70% of it out, but dont the goats have the same 4L60E I have as well? Maybe start with 50% and go from there.
    Yah I think its still the same 4L60E with a TCM. With the reduction you applied, did you ever log any of the shifts for spark retard?
    I also wonder if TM is just at the shifts or is it still present during spool up. The LS2 is a different beast!
    1-954-703-5560
    Torque Management is only during shifts AFAIK, it is used to pull a set degree of timing so the trans doesnt get "overstressed" which is complete BS as GM shouldnt be pairing engines and trans that cant work together.
    Just look at the TB SS with the LS2 and the 4L70E. Stock guys are blowing the trans up, and a few of these guys are 100% stock (paper air filter even). Most with less than 10-15K mi. So, GM really missed a beat on this one, it was a bad choice. Should have given them a 6L60E or 6L80E instead with paddle shifters, that would be so badass.
    Lifetime Member Rhino79's Avatar
    Jul 2006
    The Goat I tuned today was my first LS2. It had headers, different mid-pipes, intake, and thats it. Stock it put down 330hp at the wheels and 325 ft lbs. torque. The tq mgt. seems to only be on upshifts, as the customer requested, I removed 100%. It felt great, I made sure he understood what tq mgt did and what "could" happen, but he wanted it all gone. I went ahead and deleted all the Spark retard and all the Transmission retard tables too...along with a slight increase in line pressure and 0'ing the shift times, it will actually skate the ass end a little on the 1-2 shift.
    Hahaha, yep I know the 1-2 shift thing ohh so well. Right now my TB I6 spins the rear regardless of weather (wet is a little scarier though). After I got my trans fixed and my Vette servo working, I had to change the line pressure back to stock b/c it was spinning the tires waay to much. Now I get a little kick and the speedo jumps 5mph and I start accelerating in 2nd at 45mph. Now I need to change the WOT shift points back to stock as I wont hit the limiter now and having it shift at 5800 is no fun when it can do it better at 6100-6200.
    Quote Originally Posted by Rhino79
    What did the car make with headers?
    You set the shift times to 0?
    1-954-703-5560
    P.S. My shift times are 0 too, except for the firs 2 columns in the 1-2 and 2-3 areas where they are .1. Really firm, positive shifts. Instead of losing ground now b/c so much timing is pulled, I jump a little ahead (really nice for those race-thingys).
    Jul 2006
    Yeah, I set them to 0, but unlike the LS1's there is another table that leaves adaptive shift learning active even with the shift times at 0. It was nice and firm. He has not gone back to the dyno yet, will see soon how much headers, intake and tune was worth.
    Stock he ran 13.6 with a 2.2 60' and with the headers before the tune he ran 13.1 with the same 60'. He will be going back to the track probably within the week or at least by next week.
    so when pulling tqmgt what tables do we alter?
    04 kids ages 5-8-13-17 mabye more? hope not!
    03 toy box's 300+ rwh toys in each
    01 wife with 07 TBSS LS2 6.0 my pmt.
    01 pretty nice house my wife wanted.
  1. Torque reduction
    By Boosted GMC in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 4th, 2009, 06:42 AM
  2. TCM Torque Reduction Q
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2007, 06:02 AM
  3. Torgue management/reduction?
    By 1FastZ in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2007, 08:12 AM
  4. Torque management, TCS, TCS fast torque loss
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 04:16 AM
