Results 1 to 3 of 3
Thread: 159 litre fuel tank???
    Jan 2007
    Default 159 litre fuel tank???
    Does anyone have a 159L tank in their vehicle?
    I'd like to look at the fuel parameters please.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Aug 2006
    Hey Howard, I wonder if those numbers are in Tunercat and could be pulled from your old PCM?
    Jan 2007
    Default Good point.
    I'll look through some of my old tunes and see if I can see anything there.
    Howard
    DUCT TAPE.
  1. Took the GTO out to fill up the tank.....
    By 10secvette in forum Gen IV V8 Specific
    Last Post: July 24th, 2009, 11:08 AM
  2. changed fuel tank size
    By evilspyder66 in forum General (Diesel)
    Last Post: March 29th, 2009, 12:33 PM
  3. Holden Ecotec 3.6 and 3.2 litre variants.
    By Big Kahuna in forum FlashScan V2
    Last Post: November 21st, 2007, 07:06 PM
  4. Fuel Tank Parameters
    Last Post: April 7th, 2007, 10:57 PM
  5. Adjusting fuel tank measurements?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: July 20th, 2006, 08:53 PM
