Results 1 to 3 of 3
Thread: Issue with V7.4...or just me???
    Jan 2007
    Default Issue with V7.4...or just me???
    I noticed something today whilst making some small alterations to my VE table.
    Usually when I put a number in the 'adjust' box at the top of the page and hit the +/- button it updates the cell I'm adjusting.
    However, sometimes when I do this...nothing happens. Problem is I was thinking "maybe I didn't click it properly". I discovered when I move to another cell and click on it, the previous cell then updates.
    Each time I did this...until I discovered what was happening, I was half way through my table and was unsure as to how many 'changes' I'd made to the 'non-updating' cell.
    This meant reverting to the saved tune and starting again from scratch...no big deal...just annoying!
    So, is it an issue...or is it just me.
    These are the cells I noticed it happening in:
    Main VE Table...COS3:
    1600x35, 2400x65, 2000x85, 2400x85, 2000x90, 2000x95.
    There may be others but this is where I noticed it.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Oct 2004
    I just tried this and it appears to update the correct cell at the time I press the +/- button
    Andrew
    EFILive Crew
    Jan 2007
    OK,
    I just noticed a pattern.
    Whilst making the adjustments in my Main VE table. Eg, If I need to add 1.0 to two different cells, I put the 1.0 in the 'adjust' box and choose the cell I want to adjust. I click adjust and the cell is immediately altered. Now, if I choose another cell which I also want to adjust by 1.0 and just click 'adjust' without altering the amount, the number in the second cell doesn't change until I select another cell.
    Howard
    DUCT TAPE.
  1. 427 L92 a4 GTO issue
    By 10secvette in forum Gen IV V8 Specific
    Last Post: January 26th, 2014, 11:32 AM
  2. New Guy with TCC Issue
    By OldGreg in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 30th, 2009, 04:21 PM
  3. LC-1 Issue
    By jermstyle in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2009, 10:36 AM
  4. BBL and E38 COS Issue
    By swingtan in forum FlashScan V2 BB Logging
    Last Post: October 29th, 2008, 11:00 AM
