Results 1 to 10 of 13
Thread: Bootloader Rejected
    Apr 2007
    Default Bootloader Rejected
    I'm trying to download the stock ECM tune. It starts communicating with the ECM and then I get the following message:
    Preparing ECM for reading flash
    ECM seed is $78D3
    Error
    Disconnecting
    Disconnected
    then a box pops up that says :Error - Bootloader rejected
    Reason - No Reply
    I'm using the latest version of EFI Live.
    Any suggestions?
    Aug 2004
    Did you select the correct pcm type from the drop down menu on the read box? usually it is the cause. If not, let me know and i will help get you figured out.
    Apr 2007
    I did that before trying to scan the ECM. I've got a 2004.5 LLY.
    Do I need to disable OnStar? If so, what fuses need to be pulled?
    I've got a Compustar alarm / remote that I don't know how to disable.
    Aug 2004
    NO when you get onto the Read pcm section, there is a drop down menu you have to select the lly pcm type. Im not talking about the one in the scan tool.
    Apr 2007
    I did select the LLY controller type in EFI live. I started originally with version 7.3 and it didn't work at all. When I upgraded to 7.4, It looked like it was going to work, but then gave me the error message.
    Aug 2004
    IF the read screen is like this, and you changed it to say lly and it still dont work..... Do you have an aftermarket radio? If so the box they use on them does not shut off comunication so you need to pull the fuse for it then. Radio fuse under the hood on the drivers side.
Name:	New Bitmap Image.JPG
    Apr 2007
    My screen looks just like that. I have the factory radio so that's not the problem. Perhaps it is the alarm. I've got to figure out how to disable it completely.
    Aug 2004
    What firmware does the V2 have in it? the latest is 55
    Apr 2007
    I upgraded it to 55 as soon as I got the unit.
    Aug 2004
    Does the v2 say it is in CAN mode on the screen when it connects to your truck? Does the V2 read the vin?
  1. bootloader rejected
    By relentless addiction in forum Duramax LLY
    Last Post: May 25th, 2010, 07:26 PM
  2. ls3 bootloader rejected
    By rubbersidedown in forum Gen IV V8 Specific
    Last Post: April 13th, 2010, 11:21 AM
  3. Bootloader rejected
    By lilly in forum Duramax LLY
    Last Post: June 28th, 2009, 02:48 AM
  4. bootloader rejected
    By dmax687 in forum Duramax LLY
    Last Post: November 8th, 2008, 12:43 AM
  5. bootloader rejected PCM locked
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: July 30th, 2008, 10:16 AM
