Results 1 to 7 of 7
Thread: boost a/f
    Mar 2007
    Default boost a/f
    Ok so i am cos5..3bar. Under boost it says its commanding 8.5-9 afr...where is this command coming from? my pe is set to all 11.7
    b3647
    Mar 2007
    hmmm it says 11.5 in the 100kpa row.....anywhere else
    Quote Originally Posted by Cablebandit
    Check the ECT modifier. Should be 1.0 65C and up.
    Post a log.
    Mar 2007
    emailed to ya tom THANKS!!
    Mar 2007
    a0008 is 1.0
    Mar 2007
    think i found it...3618 has some RICH SETTINGS that seem to correspond to what i am seeing...yours is 11.7 Tom so i will change that. Does look to be the prob.
  1. What AFR in Boost?
    By zapp168 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 24th, 2007, 01:03 AM
  2. Use MAF for off boost/2 Bar SD when in boost
    By Earl H in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2007, 12:58 PM
  3. Boost and EGT's
    By minytrker in forum Duramax LB7
    Last Post: February 14th, 2007, 03:41 AM
  4. Can you log boost?
    By AustinL911A in forum General
    Last Post: January 5th, 2006, 07:55 AM
  5. What happens when you go into boost?
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2005, 05:49 PM
