I did completely remove everything EFILive related. I re-installed the latest version of 7.4 (01). Then I click on the first of the two 02 links (the second one says MD5 checksum?). It says "Open/Save/Cancel". I hit Save. I send it to Program Files/EFILive/V7. It downloads, I open it, it's in a zipped folder (yellow) and when I open that there is a blue and white rectangle that you're supposed to unzip. It won't let you unless you place it outside in the V7 folder where "obdiiV7" is. Then it turns into the Tune Tool (7.4.1.621).
