Of my maps Im having a hard time getting a stable idle go figure
I want to make sure my rafig maps are ok. Do I use the number copy paste or add.
Any info appriciated
never mind I found it theres one in the new upgrade. aaaaaaa. Im at my ends meet with this thing. Its jumpin all over the place dam it.
Unable to see your map (says invalid archive). When logging RAFIG, you are recording the corrections. So, you need to add the results to the map.
If it is "Jumping" then my first question is are you totally sure that you are in OLSD? Do you have the MAF failure? Are all of your vacuum, PCV lines tight and not leaking?Originally Posted by 98SS2836
Help is here.
www.efialchemy.com
www.greatamericancarwar.com
No leaks, maf failed. no pcv. But Im going to have to get back to you about the staying in OLSD I know at first it does but I have to make sure when it starts bouncing that it stays in it. Im going to look at in depth tomorrow.Originally Posted by Doc
Thanks very much about the help. Im going to need some of it. Im going to a mustang dyno day saturday I want to represent. I was going to bring our 830rwhp prochared 91 rs camaro but The front of the crack ate it.
