Results 1 to 8 of 8
Thread: reduced power mode
    Apr 2005
    Default reduced power mode
    Something odd is happening on my 2000 C5. I am doing all of my tuning and driving in Speed Density mode, and it seems every few drive cycles, I get reduced power, and have to go in and clear all the dtc's. Here is the list of DTC's I get.
    Diagnostic Trouble CodesP1514MAP/MAF - Throttle Position Correlation P0103Mass Air Flow (MAF) Sensor Circuit HighP0106Manifold Absolute Pressure (MAP) Sensor PerformanceP1514MAP/MAF - Throttle Position Correlation P0103Mass Air Flow (MAF) Sensor Circuit HighP0106Manifold Absolute Pressure (MAP) Sensor PerformanceP1514MAP/MAF - Throttle Position Correlation C1278
    Mods are.... 224/228 cam/ Crane 1.8 rockers, 42lb injectors, AFR 205 heads, and Headers/exhuast. Running OS5
    Any input would be greatly appreciated, I don't see why I should get reduced power. Car runs and drives great, except for a rolling idle issue I am still trying to sort out.
    P1514 relates to table C6101... trying increasing that table (I can't view your tune on this PC right now, so I can't see if you already did that).
    Also look at the MAP rationality table (under Engine Diagnostics).
    Apr 2005
    I have Map rationality test high at 5000rpm, and low at 400. SHould I set this up out of the way?
    I moved C6101 up 300% can you set that table too high?
    Thanks for the feedback.
    Apr 2005
    Did you have a chance to look at the file? I went back to stock + 50%, and haven't gotten the reduced power mode yet, but it's only been 2 drive cycles.
    ANy input is always appreciated!
    Thanks.
    I have looked at your file, and here's my suggestions:
    a. set each of the "out of range" parameters to some valid value...
    e.g. if 8000 is the max, set it to 7999, save file, and then set it to 8000;
    do this for each parameter that is out of rannge; when finished, close the file and reopen it, and now there should be none out of range anymore.
    b. try increasing some of the low areas in the ETC predicted air table; but first try your stock+50%.
    c. try setting B1901 to 500, say.
    Jan 2005
    Try something like the attached table. Works with no problems on my '01 C5 with 232/236 cam, ported heads, ported throttle body, headers, high flow cats and 3" exhaust
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Quote Originally Posted by dfe1
    I had the same happen to me
    dfe1's table worked for me.
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Apr 2005
    Thanks for the input guys! I'll try the suggestions and see where we end up!
    Jason.
  1. Tables for reduced power mode
    By MadMaxHSV in forum Gen IV V8 Specific
    Last Post: June 7th, 2010, 09:56 PM
  2. Reduced power mode Again!...........
    By FreddyG in forum Gen III V8 Specific
    Last Post: November 16th, 2007, 08:08 PM
  3. Reduced Power Mode...............
    Last Post: November 13th, 2007, 06:13 PM
  4. Reduced Power Mode but No DTC
    By CTP Racing in forum General (Petrol, Gas, Ethanol)
    Last Post: July 20th, 2006, 08:50 AM
