Results 1 to 7 of 7
Thread: 96# injectors :(
    Mar 2007
    Default 96# injectors :(
    i cant get these things to go below 1.6ms no matter what i change. Shouldnt the pcm try to pull them lower even if they wont actually work lower? This is killing my mileage. I am olsd cos5. a/f at 11-13 is killing my mileage. oF course with ANY load the a/f goes to 14.7 in autove mode. Any idea why i cant get the pcm to ask for lower than 1.6ms? I got every injector related table i can find cut up to 75% and it makes NO difference.
    Jan 2005
    You might want to try searching for post from NitroRocket. He was able to get some 90+# injectors to work. IIRC, one of his tricks was to low the base fuel pressure.
    Mar 2007
    thanks!! I know the voltage and ifr helps but didnt know about the "-" small pulse trick
    Mar 2007
    eureka!! ill post more later but those things work!!!!
    Mar 2007
    off the top of my heads I set
    small pulse adjust to -3.9
    injector flow rate at 13hg and higher (my eboost reads vacuum in hg i think) to 100 (efilive max)
    and my fuel pressure was already at 43psi hose off.
    This gets my inj ms down to 1.4...idle is 14.7 and decel is 13.0 ish.....i think i can get it better but that was just the rough start.
    It improved my mileage tremendously and am now starting to see light at the end of the tunnel.
    Jan 2005
    glad it's working out for you.
  1. L98 Injectors
    By nqcv8 in forum Gen IV V8 Specific
    Last Post: August 17th, 2008, 03:59 PM
  2. 96 lb/hr injectors
    By thosewhohatedmecreatedme in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2006, 04:57 AM
  3. Injectors...
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2006, 03:11 AM
  4. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
  5. Going from 28.8 injectors to SVO 30# injectors
    By 02 pewter Ls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2005, 01:47 AM
