Shouldn't be a problem. I tuned an 06 in March of last year with a much earlier version of the software and it worked just fine.Originally Posted by tblu92
Justin
Justin
Well I am lost then as every '06 that i've done is stuck at 14.63 at WOT with oscillating 02 sensor voltages--should mean that it is stuck in closed loop--Each customer would not allow me to put a new bung in so i could throw a wideband on it so I could get a little more information---I guess I will insist on the next one--but I still think the AFR's will be 14.63----1st issue in my 3 years of tuning so far that i haven't been able to resolve and it's driving me nuts !!Originally Posted by dc_justin
I just ran across this exact same thing - did you ever figure it out??
I thought mine was because the owner had converted the truck to a 6 speed and the computer was thinking it was in Park/Neutral. It does the same thing (stock tune in it) - won't go into PE - however, I had a wideband on it, and it was actually way rich. But not commanding PE.
I wanted to flash it to an M6 OS, but so far there are no compatible 6 speed OS's out there that I can find.
Same as you, this one has me stuck!!
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
Never did figure it out--But i agree i now think it is going into PE just the scanning data isn't picking up the correct information--BUT what throws me is that the 02 voltages should lock-on around (.890-.940) regardless in open loop-but they continue to oscilate--as if it was in closed loop ???????
Mine was locked in open loop for tuning and the A/F did not drop down rich when I went WOT - it was rich the whole time. Maybe we have 2 different problems?!?
GM EFI Tuner
Yeah--mine seems to be locked in "closed loop" all the time--and doesn't show any enrichment at WOT but stays at 14.68--seat of the pants tells me that it IS in PE because it pulls harder after the tune--I think still it is the reporting from the scan program that is at fault--I've tuned about 30 07's
and they all act the same way---
