Results 1 to 2 of 2
Thread: Normal/Performance/Hot/Cruise modes
    Feb 2004
    Default Normal/Performance/Hot/Cruise modes
    What are they? What're the criteria for determining which column the PCM uses? Is it related to http://forum.efilive.com/showthread....rformance+mode this post, as in can you wire up a "track" switch?
    01 C5 'vert A4
    EFILive, PLX, & TNT are all we got at the moment.
    Normal - Consider this the default shift pattern, ALL vehicles would normally use this.
    Performance - Some vehicles have a 'performance' , 'sport' , 'Tow/Haul' mode, it basically just gives you an alernate shift pattern for better performance but probably get worse MPG.
    Hot - If the trans has overheated this shift pattern will be used (not selected by the driver).
    Cruise - Used when the cruise control is active.
  1. switched modes??
    By truethinker in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 16th, 2012, 02:03 PM
  2. transmission normal and performance mode
    By Eric in forum Gen III V8 Specific
    Last Post: September 12th, 2009, 04:20 AM
  3. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  4. Knock modes
    Last Post: October 26th, 2006, 06:08 AM
  5. What do the different TCC modes mean?
    By thunder550 in forum General
    Last Post: May 6th, 2006, 10:36 AM
