Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Nitrous Bottle Pressure logging
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Default Nitrous Bottle Pressure logging
    Now that my fuel pressure is on the EGR PCM Pinouts (Thanks a Bunch TAQ!), that free's up the second input on my trusty Ol' V1.
    Here are the Particulars of the sending unit for my Dynotune Nitrous Pressure
    Nitrous pressure Sender Output = .005V per 100 psi
    PSI Volt
    0 2.547
    100 2.552
    200 2.557
    300 2.562
    400 2.567
    500 2.572
    600 2.577
    700 2.582
    800 2.587
    900 2.592
    1000 2.597
    1100 2.602
    1200 2.607
    1300 2.612
    1400 2.617
    1500 2.622
    This voltage is read from the black wire.
    Little help making the PID for this?
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Something like ((Voltage - 2.552)*20000) + 100, should work.
    Jul 2006
    Thanks that seems to work great (in Excel for various values), is there a way to force a 0 reading if the voltage 2.547 or slightly less (for when the bottle is not in?)
    Maine USA
    Sep 2003
    Oops, I missed the zero reading. I think that this is what you are looking for.
    (({EXT.AD1} - 2.547) * 20000) = PSI
    Sorry about that.
    Jul 2006
    No problem Appreciate the help
    Maine USA
    Jul 2006
    So is this what I need for my User calc file? *CLC-00-002 being what I am adding on AD2 input?
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    # See sae_generic.txt for more information on the *UNITS section
    *UNITS
    #Code System Abbr Description
    PSI Imperial PSI "Pounds Per Square Inch"
    # Add slot definitions here
    #Units Low High Fmt Expression
    *CLC-00-001
    PSI 0.00 100.00 .2 "({GM.EGRS}*25)-12.5"
    *PRN - Parameter Reference Numbers
    #Code PRN SLOT Units System Description
    CALC.FP F001 CLC-00-001 PSI Fuel "Fuel Pressure"
    *CLC-00-002
    PSI 0 1500 1 "(({EXT.AD2}-2.547)*20000)"
    CALC.NP F002 CLC-00-002 PSI Accessories "Nitrous Main Line Pressure"
    Maine USA
    Sep 2003
    That should do it. I think you can leave out the first '(' and the last ')', but it shouldn't bother anything. I left them there from the first equation.
    I like the color of your car. I have a 98 Nassau Blue coupe.
    Beer,
    I took the liberty to "optmize" your calc_pids... see attached...
    (psi units are already pre-defined)
    Cheers
    Joe
    FlashScan A/D inputs are accurate to +/- 0.01V, so measuring down to 0.005 Volts will not be 100% accurate.
    The PSI displayed by EFILive will be accurate to +/- 200PSI
    And to get it to display 0 under 2.547V, you could do this:
    (oh and I changed the precision to 0).
    Code:
    psi    0    1500    0    "Iff({EXT.AD2}<2.547,0,({EXT.AD2}-2.547)*20000)"
    Quote Originally Posted by Beer99C5
    PSI Volt
    0 2.547
    100 2.552
    200 2.557
    300 2.562
    400 2.567
    500 2.572
    600 2.577
    700 2.582
    800 2.587
    900 2.592
    1000 2.597
    1100 2.602
    1200 2.607
    1300 2.612
    1400 2.617
    1500 2.622
    Jul 2006
    Thanks all, not sure if 200 +or - is worth the effort now, I will try it though (its only one wire 2' long). Both V1 and V2 have the same A/D inputs accurate to +/- 0.01V?
    Maine USA
  1. nitrous help
    By blue99ta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 26th, 2009, 05:40 AM
  2. LB7 Oil Pressure logging
    By GMPX in forum General (Diesel)
    Last Post: December 7th, 2007, 06:22 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Bottle neck? How to determine if present
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 04:30 PM
  5. Boost pressure input and logging
    By diynoob in forum External A/D inputs
    Last Post: March 4th, 2007, 02:08 AM
