Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Nitrous Bottle Pressure logging
  1. #11
    Jul 2005
    this is a very small range of values to express a large range of pressures, can you pick values for range and domain arbitrarily?
  2. #12
    Lifetime Member Doc's Avatar
    Oct 2005
    I am not logging the values but this is what I am using to maintain bottle pressure.
    http://www.ifmefector.com/ifmus/web/..._10_10_10.html
    I have it hooked up to a relay to control the on / off of the blanket. It accurate to +/-2psi. Independant testing in my lab verified their claim using a King Nutronics Precision pressure standard.
    www.efialchemy.com
    www.greatamericancarwar.com
  3. #13
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Well hooked it up, read 1259 with a actual pressure 580 or so...
    2.61 Volts fairly steady...1259 PSI from the PID
    The voltage was pretty steady and the PSI matched the formula.
    Guessing I need to offset the voltage? How do I do that to try and match the actual pressure?
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
  4. #14
    Jul 2006
    Hooked it up to the V2, the Voltage range is just too tight with the Dynotune Sending unit fluxuated badly as Blacky said it would, will revist this with a different sending unit (one that uses most of the 0-5v range) later...on to COS 5
    Maine USA
  5. #15
    Jul 2006
    Going with the Autometer 0-1600 sending unit from Summit...ordering tonite, hope to have it installed first week of Nov.
    Bored here in Singapore...Drew a Nitrous Bottle in 3dsMax and imported it for a Pressure guage.
    Maine USA
  6. #16
    Feb 2007
    Very cool!
    2004 Pontiac GTO - Quicksilver/red/m6
    1-of-344
  7. #17
    Oct 2006
    Beer, since my EXT.AD1 input is used for my LC1 can I do the same as you exept use the EXT.AD2 input for logging nitrous pressure??? then use the same common groung on the V1 as I did for the LC1???
    THANKS
  8. #18
    Jul 2006
    Yes that should work. Thats how I hooked up my V1 for WB and fuel pressure at first. Then I modified the fuel Pressure to work through the EGR Pinout in the PCM (Good Unused 5V source).
    Maine USA
  9. #19
    Jan 2005
    I like that dash Beer. Kinda reminds me of a process control graphic!
  10. #20
    Oct 2006
    Quote Originally Posted by Beer99C5
    Cool now all I need is the custom PID for the autometer sending unit..hint hint
  1. nitrous help
    By blue99ta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 26th, 2009, 05:40 AM
  2. LB7 Oil Pressure logging
    By GMPX in forum General (Diesel)
    Last Post: December 7th, 2007, 06:22 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Bottle neck? How to determine if present
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 04:30 PM
  5. Boost pressure input and logging
    By diynoob in forum External A/D inputs
    Last Post: March 4th, 2007, 02:08 AM
