Do the 2001 c5's have that unused 5v source pinout in the pcm since that year has no egr???
Actually I need to log Nitrous pressure and my standalone fuel system fuel pressure... Beer gonna shoot you a PM....
For the "Gauge and Dash Board Challenged"
Just noticed on Value I need to change it to 4 digits
1999 C5 A-4 Convertible
1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
Maine USA
Sending an email to autometer on the scaling of there sending unit today...I had it once but do not have it on my laptop...I think I have a spreadsheet on it but want to double check...I may need help with the PID as well...should have that wrapped up by SaturdayOriginally Posted by WiseGuyZ06
Maine USA
Sweet... Im gonna log fuel pressure 1st.. cause I have a mechanical NOS pressure gauge..Originally Posted by Beer99C5
Beer do you have the scaling on the autometer Fuel pressure sending unit??? So I can log my standalone....
Also Can I use my AC wiring since its a 0-5v... I ditched the AC long time ago.. If Im not mistaken its 0-5v..
So I could use the V1 to log the NOS pressure since thats in the car and the AC wiring since thats near my Nitro Dave's standalone.... or vice versa
Just need custom PID's......
The pid for the Autometer pressure guage is in here.http://www.holdencrazy.com/EFILive/T...itTutorial.zipOriginally Posted by WiseGuyZ06
Cool, the link dont work, BUT ill use the tutorial and log it through the EGR cause it still has it in the PCM ( I have a 2001 corvette ). Ill use the EGR pid to log fuel pressure....Originally Posted by 5.7ute
So many different ways..geesh
Pressure = (Voltage-.5)*400 seems to work for the 1600 PSI gauge.
Maine USA
Autometer tech service on the 2240
The wiring for the 2240/2246 is Gray= +5VDC, Black= Ground and the Purple= Signal. The 2240 sender spec are as follows...
PSI volts
0 0.5
800 2.5
1600 4.5
Doug Lemons
Tech/Service
Maine USA
