Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
Thread: Nitrous Bottle Pressure logging
  1. #31
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Works Great!
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    # See sae_generic.txt for more information on the *UNITS section
    *UNITS
    #Code System Abbr Description
    # Add slot definitions here
    # See sae_generic.txt for more information on "SLOT" formats
    #Units Low High Fmt Expression
    *CLC-00-001
    psi 0 100 0.1 "({GM.EGRS}*25)-12.5"
    *CLC-00-002
    psi 0 1600 0.1 "({EXT.AD2}-0.5)*400"
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code PRN SLOT Units System Description
    CALC.FP F001 CLC-00-001 psi Fuel "Fuel Pressure"
    CALC.NP F002 CLC-00-002 psi Nitrous "Nitrous Main Line Pressure"
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
  2. #32
    Oct 2007
    Sweet, beer, I just got the dynotune FP gauge and dean said it wont log properly. So no logging FP for my nitrous system....that sux
    I ditched the autometer gauge, what a POS.....
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
  3. #33
    Jul 2006
    Quote Originally Posted by WHYTRYZ06
    Dont ditch the Sending unit for the Autometer Fuel gauge if it does not work send it back to autometer. I fried the first one..told them that I put 12V to it (its only supposed to have 5V) and they sent me a new one (free) when I told them the sending unit had no instructions in the packing, and I was using it for logging and not in conjunction with one of their gauges.
    I talked with Dan and Dean at Dynotune, their sending units have to narrow a voltage to be used with EFI Live (their gauges work very well though).
    Maine USA
  1. nitrous help
    By blue99ta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 26th, 2009, 05:40 AM
  2. LB7 Oil Pressure logging
    By GMPX in forum General (Diesel)
    Last Post: December 7th, 2007, 06:22 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Bottle neck? How to determine if present
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 04:30 PM
  5. Boost pressure input and logging
    By diynoob in forum External A/D inputs
    Last Post: March 4th, 2007, 02:08 AM
