Results 1 to 10 of 17
Thread: Died around 4200rpm
    Jan 2007
    Default Died around 4200rpm
    I have no idea why.
    I was logging some data for my autoVE tuning and when I got to around 4200rpm the truck just died.
    Any thoughts?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Ran out of gas?
    But seriously, does the truck restart?
    Does it die again at a similar rpm, or was it a one off failure?
    Howard,
    You have to find out if you're not getting one or more of spark/fuel/air and then trace backward from there (is the problem mechanical, electrical, or is it the tune...?).
    Is it repeatable, or does it also not start...?
    Joe
    Jan 2007
    Hi guys,
    Burb still runs fine. As soon as it happened I backed off the accelerator and it just ran normal again. No problems since.
    I'm pretty sure the truck's OK mechanically and electrically.
    I haven't tried revving it to 4000 again yet. I rarely get to those rev's...especially whilst still tuning. I eased it to those rev's on the freeway...so I was going pretty fast.
    Howard
    DUCT TAPE.
    Jun 2005
    Are you sure you were in SD?
    Are your VE values somewhat 'sane' for 4,000 on up?
    Have you checked for loose grounds?
    Nov 2003
    What Mods do you have?
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Post your tune in this thread.
    Jan 2007
    Default Some tunes and logs
    Thanks for the help guys,
    Mods are only two.
    -0411 PCM
    -Whipple SC
    The tune listed as 0001 is the one I was running when it died.
    After the attached log I altered the tune as per the tutorial (I believe...except, I forgot to alter the BoostVE table).
    The second tune (0002_smoothed) isthe currently loaded tune which I have basically only driven on to the shops and back so far...so no logs.Please let me know what you see?
    Howard
    DUCT TAPE.
    Aug 2004
    You need to remove your Vehicle speed limiter. That is what you hit.
    Jan 2007
    Default Thanks
    Thanks Jesse,
    I was looking through a few things and didn't see that.
    I knew some of you guys could sought me out.
    Howard
    DUCT TAPE.
  1. RR Died today
    By Highlander in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 19th, 2009, 06:40 PM
  2. AD2 died
    By mr.prick in forum External A/D inputs
    Last Post: May 27th, 2009, 02:46 PM
  3. Laptop Died
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2007, 10:12 AM
  4. RR died
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 7th, 2007, 02:16 AM
  5. More RR problems 3rd one died after 30 sec
    Last Post: May 18th, 2007, 01:50 PM
