Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Help Cannot flash 99 tahoe
  1. #11
    Jan 2007
    Hey Doc...you've done the swap in the Z...why not swap to 0411 in the Hoe?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  2. #12
    Lifetime Member Doc's Avatar
    Oct 2005
    That's on the massive list of things to do. Someday she will be Super Hoe.
    www.efialchemy.com
    www.greatamericancarwar.com
  3. #13
    Jan 2007
    Yeah...the list just grows and grows huh!
    You know it's about 2 hours work right?
    Have you seen James.B's Tahoe?
    Now that's a 'Super Hoe'.
    http://www.pacificp.com/forum/viewtopic.php?t=5134
    http://www.pacificp.com/forum/viewto...er=asc&start=0
    http://www.pacificp.com/forum/viewto...ghlight=#36229
    Howard
    DUCT TAPE.
  4. #14
    Oct 2005
    Quote Originally Posted by hquick
    That's funny. I would like to be able to goto the bank and finance 2 hours for myself! Too busy tuning/fixing other peoples stuff.
    www.efialchemy.com
  5. #15
    Lifetime Member Boost's Avatar
    Dec 2006
    Question thread resurrected
    Quote Originally Posted by Rocketman69
    I just had the same issue on my 99 Silverado (K1500, not GMT800) and I could not get it to take after 5 attempts....any idea what's causing this issue? I've had no issues reading them, just writing this one. Any help is appreciated. Thanks.
    I just had this same problem today on a '99 with the square headlights.
    What is causing this? It wouldn't start (start and die, like a security issue), so I reprogrammed the PCM with a Tech2, and then it started. I had the fuse pulled for the aftermarket radio, and have the latest of everything as of today.
    8.7 @ 84 (1/8 mile) bolt-ons
  6. #16
    Junior Member Rocketman69's Avatar
    Dec 2006
    Sorry I never updated this....
    What was causing my flash attempts to fail ended up being the ABS module. Unfortunately, on the 6th attempt, it started to write, then failed and put me in a situation similar to yours...the PCM would not accept a new flash because it had no idea what OS or VIN it contained....
    Paul came up with a fix for the software and was able to send me the files to load into my laptop and fix the situation with the PCM not being recognized.
    He viewed the error logs to find out that about 17 seconds into the write process, my ABS module decided to wake up and interrupt the transfer of data into the bus stream. After fixing the problem, I pulled the ABS fuse (as well as the fuse to my remote start) and attempted to reflash. This time it took without any problems. I have since reflashed it a handful of times without any problems, but I ALWAYS pull the ABS maxi-fuse from the box under the hood before I flash.
    Hope this helps.....
    -Gib
  7. #17
    Gib,
    Thanks for the update.
    That's good point: pull the ABS fuse, and the Radio and On-Star fuses.
  8. #18
    Dec 2006
    Thanks! I will try that.
  1. snow fun with the Tahoe
    By harascho in forum Lounge
    Last Post: February 21st, 2009, 06:55 AM
  2. 01 5.3/Tahoe..
    By Chuck L. in forum Gen III V8 Specific
    Last Post: August 15th, 2008, 03:15 PM
  3. have to flash ECU forProject GenIV "LMG" into 1997 Tahoe
    By harascho in forum Gen IV V8 Specific
    Last Post: April 14th, 2008, 02:55 PM
  4. 07 Tahoe e38 pcm
    By 5.3 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 10:02 AM
  5. 07 Tahoe supported???
    By 5.3 in forum Gen IV V8 Specific
    Last Post: November 27th, 2006, 02:01 PM
