I cant get it to pull timing. I have double checked the wiring and even checked the pin with a meter, switch on pin 56 is grounded on the red connector. I have been testing by making a pass with the switch off, I have 27 deg timing then turn on the switch and start a new log. Make another pass and command it to pull 10deg and the new log will show 27 still.
