Hi Guys!
I just put a Vortech supercharger put on my 2001 Corvette along with 60 lb. MotoTron injectors and was wondering if it'd be possible to change the injector pulse width or the injector offset (or some other injector setting) to lower the amount of fuel when the car is off boost. It idles nicely with minimal searching or fluctuation, but I'm trying to get maximum efficiency out of it.
I guess what I'm asking is if at idle or cruise, if I couldn't set the computer so that the injector isn't dumping the gas in.
Also, do I set my IFR according to the rail pressure at idle or when in boost?
The tuner that did my car, calculated them at 58 psi and my rail pressure at idle is 68 psi. When I go into boost, the rail drops to around 58-59 psi.
Thanks in advance for the help Guys!
