Page 14 of 14 FirstFirst ... 4121314
Results 131 to 133 of 133
Thread: My V2 is just collecting dust...
  1. #131
    Yes - limited to two controllers simultaneously (i.e. ECM and TCM) but that can be expanded in future if needed.
    There is one small limitation with the V7 software and that is you can't log the same parameter from both controllers. i.e. you can't log ECM.RPM and TCM.RPM. That limitiation is removed in the V8 software.
    {Arnold}Coooooooolllll...{/Arnold}
    Edit: I was just thinking, will the two controllers then share the total channels? Currently, I usually log 32 channels to keep resolution reasonable, so if I where to log my usual 32 from the ECM, would logging from the TCM then add to those 32 and reduce sample rate?
  2. #132
  3. #133
  1. Collecting links to scattered material...
    By joecar in forum Tutorials
    Last Post: March 31st, 2021, 11:39 AM
  2. Dust Storm Hits Eastern Australia
    By joecar in forum Lounge
    Last Post: September 23rd, 2009, 08:15 AM
