Results 1 to 10 of 18
Thread: AutoVE
    Oct 2006
    Default AutoVE
    Ok , what is the pickle here , I just went over the AutoVE tutorial in 7.4.2 , and the COS3 B3647 values are quite different in the new tutorial .
    At 95 and 100 Kpa in the old tutorial the values were 13.8 (95 Kpa) and 12.9 the first 4 cells and then 12.5 the rest (100 Kpa) respectively , the other values were 14.7 not 14.63 because that if I remember right 14.63 puts you in semi-open loop mode still using the O2 sensors .
    So anyone who used the old tutorial is going to be quite off or is the new one ?
    2006 Trailblazer
    Oct 2006
    OK , maybe I asked this the wrong way , according to the AutoVE tutorial in 7.4.2 , the values for a COS3 in the B3647 table is 14.63 (stoich) which I understand would put you in a semi-closed loop mode using the O2s still (not good) and the rest of the values are rich in the upper MAP areas , will that not eschew the WBO2 numbers ?
    2006 Trailblazer
    Sep 2005
    Ya, you don't want 14.63 or or it will use short term fuel trims and you will not get accurate BEN readings. I put 14.7 every where except the last 3 column, where I'd use 13.8, 13.0, and 12.4 for the 100 kPa column if the motor is NA. For boosted motor, I run 11.2 in the 100 kPa column.
    Jan 2005
    Good catch. !NB's prevents the short term trims in my case.
    Jan 2007
    Thanks guys,
    I guess that just solved one of my issues.
    Mine were set at 14.63 as per the tutorial.
    I just reset them to 14.7....is that correct?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Oct 2006
    Quote Originally Posted by hquick
    Thanks guys,
    If you are using COS3 or 5 , yes that is correct , 14.7 takes it out of the sudo fueling mode and puts it in commanded so to speak and no O2 sensors .
    2006 Trailblazer
    Jan 2007
    Thankyou very much. Yes I'm using COS3 with the 0411 swap in my 98 Burb.
    I've been having a couple of issues in the AutoVE area so this may solve some of those.
    Howard
    DUCT TAPE.
    Jan 2007
    You guys might want to take a look at this thread!
    http://forum.efilive.com/showthread.php?t=5144
    Howard
    DUCT TAPE.
    Oct 2006
    My OS does not have the {B3601} table , although the talk of the EQ ratio is interesting .
    Yep , can change values from EQ to AFR and will add or subtract , entered 14.71 and converted to EQ got 0.99 , then converted back to AFR value changed to 14.72 .
    2006 Trailblazer
    Jan 2007
    Quote Originally Posted by kbracing96
    Could it actually be possible that 13.8 is the peak power for some motors? Sounds lean!
    Or did you mean
    100 kPa
    12.4 AFR
    95 kPa
    13 AFR
    90 kPa
    13.8 AFR
  1. Replies: 32
    Last Post: June 24th, 2010, 06:21 AM
  2. AutoVE help please
    By LS1-450 in forum Gen III V8 Specific
    Last Post: May 6th, 2009, 09:23 AM
  3. doing autoVE
    By nathans1987 in forum Gen III V8 Specific
    Last Post: May 3rd, 2009, 06:20 PM
  4. autove afr
    By 91LS1S10 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 14th, 2006, 07:59 AM
  5. AutoVE, What next?
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: April 11th, 2006, 08:45 AM
