Results 1 to 6 of 6
Thread: Small Injectors/LS6 Intake
    Oct 2006
    Default Small Injectors/LS6 Intake
    I just installed an LS6 intake on my 2000 Formula. It still has the smaller 26lb. injectors. My car is currently running on an 02OS with the 00 IFR table copied over. Should I change my IFR? If so, how much? Should I use the 02IFR? Thanks for any help.
    Oct 2004
    Use the OS for the injectors you have - most likely from your stock OS. The injectors changed to 28.8lb with the LS6 intake.
    Andrew
    EFILive Crew
    Oct 2006
    Quote Originally Posted by Tordne
    I know that, but was wondering if the IFR should be adjusted. I take it not. Thanks.
    Use the IFR that came with your 26lb injectors (i.e. the '00 IFR).
    Jul 2005
    IFR describes injectors ONLY. so if you stayed with old injectors, leave the old IFR in.
    Oct 2006
    Got it - will do. Thanks, guys.
  1. Mercruiser Marine intake injectors
    By onegonewild in forum Vortec V6/V8 Specific
    Last Post: July 22nd, 2008, 11:21 PM
  2. Injectors that come w/ L76 intake (from SDPC)......
    By WHYTRYZ06 in forum Gen IV V8 Specific
    Last Post: November 29th, 2007, 06:02 AM
  3. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
