Every time I shift into gear(auto trans) or neutral,From neutral to park,From park into gear.I can go from 1st to drive or into 2nd,Pretty much anytime I move the shift lever or come to a stop it dies out for a split secondView My Video
Yes that can be tuned out. What all mods do you have? Can you post your tune?
Please tell me how.PP heads,small cam VHP 551 lift I forget the duration,header's,3600 stall,3.73's.No clue on how to post my tune ............Paul *UPDATE* I figured out what it was.I zeroed out B4512 filtered RPM airflow correction and it solved the cutting out and I copied and pasted from the stock tune B4514 Learned airflow correction and the car idles perfect now.Thanks anyway Minytrker..................PaulOriginally Posted by minytrker
