Results 1 to 6 of 6
Thread: Can Valet mode be used to turn SD mode off and on?
    Mar 2005
    Default Can Valet mode be used to turn SD mode off and on?
    Not sure if this is even what I would want but it would give us an idea of what can actually be controlled..
    I can't really think why you would want to??.
    In any case, yeah, the valet mode switch as it is now I have made it serve a few purposes. It may not stay that way, just testing the other options. It would be nice if the PCM had more spare inputs and outputs.
    Mar 2005
    Thanks Ross.. pretty much after the extent of what valet mode can do. There are still a few out there that are running two tunes or would like to.. one for the street (9psi)and one for the track(16psi). My assumption is that a 2bar could accomplish this with one tune but say they didn't go 2bar SD.. could they use valet to switch between tunes?
    Jul 2003
    Quote Originally Posted by ForcedC5
    I don't think there is enough space in the pcm... maybe in the 8mbit.
    Mar 2005
    Quote Originally Posted by The Highlander
    Hmmm.. 2003+ PCM.. Since SD is a better option altogether, most likely not worth the hassle of a swap even if it is an option unless other features present themselves.. maybe.
    Unfortunately there is not many spare in's and out's on the PCM.
    The switch input 'may' end up being multi function that you will need to change with a reflash (got 30secs spare!!). I'm still working on that.
    One with be a neat NOS deal.....just testing that now......O.K, so NOS is illegal in Australia, but we can see the desired result.
  1. valet mode
    By vortecfcar in forum General (Diesel)
    Last Post: September 5th, 2007, 03:53 AM
  2. E40 Valet mode?
    By ringram in forum Custom Operating Systems
    Last Post: April 27th, 2007, 10:21 PM
  3. Valet Mode
    By ZL1Killa in forum Custom Operating Systems
    Last Post: April 10th, 2006, 01:08 AM
