Results 1 to 8 of 8
Thread: High idle on start up..
    Default High idle on start up..
    this is starting to get on my nerves now..right as i start my truck up, it will rev up to 2 grand and then within 3-5 seconds it back down to 700..any one got any ideas
    6.0 230/226 cam ported ls1 heads and ls1 intake, cos#3 speed density
    Jan 2005
    Off the top of my head, startup airflow, startup friction airflow, idle flare control.
    Sep 2003
    Is the intake air tract, sensor contacts, throttle body ect. all clean and in good working order? If so, then what TAQuickness said.
    Most of the time I have seen this it is a mechanical maintenance issue.
    I'm old and Retired! I used to go fast. I don't go so fast anymore ...but, my cars still do!
    Quote Originally Posted by Maggie
    nothin behind the throttle body leaks..i have a few ahead of the throttle body but thats not going to cause any problems
    Aug 2004
    Send the file over jessebubb@yahoo.com ill fix it real quick.
    Quote Originally Posted by TAQuickness
    do i just raise or lower these.im lookin at a tune for a cammed ls1 and they are higher than mine..
    Quote Originally Posted by wait4me
    sent..thanks
    Aug 2004
    I still havent gotten it, when it does, ill make the change needed
  1. High idle after new MAF
    By Chriskaw7r in forum Gen III V8 Specific
    Last Post: May 2nd, 2011, 05:43 AM
  2. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  3. Cold start great but warm start sucks."Idle
    By mvvette97 in forum Gen III V8 Specific
    Last Post: October 26th, 2008, 12:22 AM
  4. High Idle
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2008, 04:14 PM
  5. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 02:18 PM
