Results 1 to 6 of 6
Thread: Which MAP Sensor?
    Lifetime Member mistermike's Avatar
    Dec 2003
    Default Which MAP Sensor?
    What 2 bar sensor are you fellows using? GM P/N?
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    The one I have here is '16040749', www.gmpartsdirect.com shows this as obsolete.
    The new number is - '12223861', they came from the 89 Turbo T/A's according to that site.
    Dec 2003
    I believe the 12223861 is a 3 bar sensor. I googled that number and everything comes up that way.
    I found this nifty page:
    http://www.robietherobot.com/storm/mapsensor.htm
    There's some discussion on LS1tech about using the BARO sensor from a Saturn ION, but the connector doesn't match up, which seems like a needless PITA to me.
    I'm thinking anything from a recent factory S/C 3800 would be plug and play.
    Lifetime Member SS2win's Avatar
    Feb 2005
    I asked my local dealer for p/n 16040609 and they came back with a new number 12569241 - $40 and some change. Got the original part number from this site: http://www.robietherobot.com/storm/mapsensor.htm
    2001 Camaro SS
    EFILive Custom OS3
    Feb 2005
    mistemike, the post says the baro part fits but the ION MAP is 2.5 bar with a different connector...
    http://www.ls1tech.com/forums/showthread.php?t=310536
    2001 Camaro SS
    EFILive Custom OS3
    May 2005
    I would like to know the answer to this also! I need a 2bar that will fit a silverado and I am confused by all of the part number refrences in similar posts.
    1999 RCSB: P1SC, 57lb inj, E-fans/34\" rad, 3:73-Eaton 18\" Toyo\'s, Flashscan-FJO, Griffin IC, FLP level 5 and PI 10.5\" 3-disk....
  1. TP sensor
    By Slowrc in forum Gen III V8 Specific
    Last Post: January 29th, 2009, 05:24 AM
  2. DTC O2 sensor
    By hymey in forum General (Petrol, Gas, Ethanol)
    Last Post: February 16th, 2008, 10:18 PM
  3. TPS sensor?
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2007, 12:28 PM
  4. Anyone know of a 1.5 bar MAP sensor?
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2007, 07:57 PM
  5. IAT sensor
    By Chevy366 in forum Lounge
    Last Post: August 3rd, 2007, 10:49 AM
