Results 1 to 6 of 6
Thread: Code PO101
    Oct 2005
    Default Code PO101
    Hello guys ,
    I'm having a problem with this avalanche . It's a stock motor with nothing on it except STS turbo kit . it is making 334WHP ON 7PSI with 5.3L engine in it .
    Every about 100 miles the cars power goes sharply down and it starts detonating . the MIL comes on with a code for the MASS sensor.
    PO101
    Any clue how can I get this code off of my back .
    Cheers
    Oct 2004
    Are you still using the MAF?
    Andrew
    EFILive Crew
    Oct 2005
    yes, i put it at 6 psi with 310whp. so i dont think it is maxed out .
    Jan 2005
    First thought is you're maxing out your MAF, but, P0101 is a performance code, not circuit high. So to eliminate max'ing the MAF as the culprit, I would reset all the DTC's, then set up a log to monitor the MAF airflow PID's. Take it for a drive and duplicate the problem, then cross check your max MAF airflow vs. the max value in your MAF table.
    Aug 2005
    P0101 is related to the same problem that you described in another thread. It is the MAF Rationality Test table. Increase that table some more and give it a go.
    Can you post up the values you have there?
    Justin
    EDIT: NVM, I see you posted the tune. I'll post up a modified one for you.
    Aug 2005
    Use the attached tune.
    C2911 increased by 400%. This will fix the 101 code.
    Also have adjusted the ETC tables to keep you from hitting Reduced Power Mode.
  1. Authentication Code
    By Blacky in forum Please Read First
    Last Post: August 19th, 2017, 10:53 AM
  2. egr code?
    By hutch in forum Duramax LLY
    Last Post: October 3rd, 2009, 04:55 AM
  3. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 01:57 AM
  4. code confuessed
    By cattleman53 in forum Duramax LB7
    Last Post: May 4th, 2009, 10:32 AM
  5. key code
    By beaukz28 in forum Purchase and Shipping
    Last Post: October 14th, 2008, 04:35 PM
